Shell And Tube Heat Exchanger Design
design
#1 Orzelgorskiego
Orzelgorskiego
  • 28 posts
Posted 08 July 2022 - 08:29 AM
Could somebody check whether I made correct calculations. Thank you.
I need to design a shell and tube heat exchanger to heat up the water. For heating, water vapor at 100degC will be used in shell side.
TUBES
Flow of water 6500m3/hr
Temp of heated water 90degC
Temp initial of water 10degC
SHELL
Flow of water vapor 1500kg/hr
Water vapor at 100degC
Energy from water vapor assume 2200kJ/kg * by amount of water vapor 1500 kg/hr = 3 300 000kJ/hr
Energy needed to heat up the water 2 174 276kJ/hr
70m2 heat exchanger will be ok for such application? What else should I take into account when design such S&T heat exchanger?
Thank you
Tomasz
Edited by Art Montemayor, 11 July 2022 - 12:57 PM.
foreign internet signals information deleted
  • 6,982 posts
Posted 08 July 2022 - 11:59 PM
You need to go back to the basics , probably take a look at your notes .
How can you get negative Surface ???
It seems to me you don't know how to perform an heat balance .
Energy in = Energy out .
During heat transfer , the steam will be converted to water , energy transferred is the latent heat * steam flow rate ,meaning the temperature of the outlet water is the same than the steam inlet .
Review the DT ml accordingly..
Anyway I will supply some documents to support your work .
#3 Art Montemayor
Posted 10 July 2022 - 06:26 PM
Tomasz:
I have to assume you are a student.  What year of engineering you are presently studying is something that would be of interest.
The reason I state the above is because if I am correct, then this thread belongs in the Student Forum and not here in the Process Heat Transfer Forum that is meant for practicing engineers.  Also, knowing that you are a student and not a practicing engineer helps us experienced engineers understand your errors and most importantly your needs and how we can best help you.  Please reply if you are a student and I will transfer this thread to the Student Forum.
Your proposed heat transfer problem is a typical academic example.  It should be easy to resolve it if you just supply all the facts.
#4 Orzelgorskiego
Orzelgorskiego
  • 28 posts
Posted 11 July 2022 - 01:09 AM
Dear Admin,
Thank you very much for help.
I will try to manage with this issue.
I am not a student, however I helping to solve some tasks for my brother which is a student in Poland :)
Thank you
Tomasz
