Torsion In A Tank
industrial professionals
#1 KevinGTX1
KevinGTX1
  • 13 posts
Posted 21 July 2022 - 03:53 PM
Hello. Do you know if hydrostatic pressure applied to a tank's walls can cause the structure to twist?
#2 latexman
latexman
  • 1,896 posts
Posted 21 July 2022 - 06:40 PM   Best Answer
IIRC from Statics 101, hydrostatic pressure applies normal to the tank walls/containment structure, so I don’t see how any torque can be developed. But, I’m going to follow this thread.
#3 breizh
  • 6,954 posts
Posted 21 July 2022 - 09:48 PM
Agree with Latexman ,why do you ask this question?
Any problem with an agitated tank or reactor?
#4 KevinGTX1
KevinGTX1
  • 13 posts
Posted 23 July 2022 - 03:17 PM
Hi
I'm looking at a project that involves designing a storage tank.
Rings of stiffeners were installed into the tank's top and bottom. Why it is used intrigues me.
There is no information in the API650 ANNEX V regulation that I reviewed. It just specifies the stiffener and section placement height.
Apply the hydrostatic pressure forces during the analysis using a FEA tool. The end effect is a 0.16° displacement twist. I decrease the displacement to 0.5° by applying a stiffener. Use RFEM 5 to perform the analysis.
How may hydrostatic pressure cause the structure to experience torque? Is it possible?
#5 KevinGTX1
KevinGTX1
  • 13 posts
Posted 23 July 2022 - 03:37 PM
the design images are included.
  • Attached File  HP.JPG   53.25KB   1 downloads
  • Attached File  HP 2.JPG   49.86KB   0 downloads
#6 horatorres
horatorres
  • 88 posts
Posted 25 July 2022 - 07:56 PM
I am not a tank designer,... But in real life it never happen that Hydrostatic pressure gave torc to the tank.
Horacio
