H2S Removal From Biogas
#1 Aliceat2000
Aliceat2000
Posted 24 July 2022 - 03:56 AM
Hydrogen Sulphide is usually separated from biogas through activated carbon vessels.
The process is improved by injection of small rate of O2.
Knowing the biogas flow rate, H2S concentration, pressure and temperature, how can I calculate the amount of activated carbon needed, diameter of the vessel, height of the vessel, and amount of oxygen injected?
  • 6,942 posts
Posted 24 July 2022 - 07:08 AM
A few pointers within  the documents attached .
https://tspace.libra...MASc_thesis.pdf
In the document from clean tech you will find the benefit to add O2 .
