Dilution Steam In Olefins Plant
#1 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 29 July 2022 - 08:02 PM
Dear Sir,
I wanted to now what all process parameters are monitored for Dilution Steam Generator System in Ethylene Plant .
Also what will be normal values for Total Organic Carbon (TOC) and Oil & Grease for Proces Water Stripper (PWS)?
Best Regards,
CHEMSTRONG
  • 1,635 posts
Posted 30 July 2022 - 07:59 PM
Olefins crackers operate at low pressure after the furnace hydrocarbon feed is mixed with steam. This dilution steam can be generated from recovered process water. The olefins plant should have a set of books provided by the plant designer describing the process and would be an excellent place to begin learning the whys and hows of the process. A web search also reveals useful information such as this report on dilution steam generation: https://www.klmtechg...ROCdraft5.0.pdf
#3 breizh
  • 6,939 posts
Posted 31 July 2022 - 03:20 AM
May be the kind of resources you need : https://www.intechop.../chapters/78591
A good start will be your favorite search engine .
