Aspen Plus Air Stripping Problem
#aspen plus
#1 Yanzi233_
Yanzi233_
Posted 02 August 2022 - 02:05 AM
I'm trying to stimulate an Ethyl Acetate Air Stripper in Aspen Plus V11, using RadFrac model (PACKABS).
I wanted to air strip the Ethyl Acetate in Feed stream, but the Top/Bottom Temperature can't be corresponding to the Actual Temperature.
When using RadFrac without condenser and reboiler, the Bottom Temperature will be lower then the inlet air temperature. (< 25℃)
When using RadFrac with reboiler only, the Bottom Temperature will be much higher (>58 ℃) than the actual temperature in real situation.
Is there any ways to adjust the temperature to match the real situation? Thanks so much for the responses!
Ps: Pls see my process and components in the attached files.
  • 7,062 posts
Posted 02 August 2022 - 03:19 AM
Try to simulate with a smaller quantity of EA , let say half of the quantity .
Using a simple calculator with 2 components (water +EA)  using Henry's law ,  I got a warning saying that the liquid is oversaturated , meaning part of EA will go to the bottom with liquid due to bubbles formation .
I don't have simulator to support .
What about the thermodynamic  package , do you use the right one ?
note : If you have access to youtube channel , you will find examples where Radfrac is used .
Hope this is helpful .
