Horizontal Check Valve - Ball Type Failure
check valve ball check valve check valve failure
#1 Frederick34
Frederick34
  • 3 posts
Posted 12 August 2022 - 01:29 PM
Hi everyone!
I'm process engineer in an oil refinery. A couple of months ago, we observed backflow in a caustic line due to the failure of a check valve.
The check valve was a ball type without spring (you can observe the diagram of this valve below)
I didn´t find any special requirements for check valves in caustic services (beside material or tracing requirements). So I suppose that ball types are suitable for caustic solution.
Is it possible have a failure (backflow) in an ball type check valve without spring as show in the table below?
Thanks!
#2 Bobby Strain
Posted 12 August 2022 - 03:22 PM
Seems like you provided the answer in your query.
#3 breizh
  • 6,939 posts
Posted 12 August 2022 - 10:15 PM
I had similar issue with a water network  contaminated with caustic due to check valve failure . The objective was to dilute caustic with industrial water but because of the issue we changed  the process , adding a tank to prepare the mixture .
Difficult to rely on a check valve when there is a risk of contamination , sometimes people use 2 check valves .
Note : caustic soda is very viscous and tends to crystallize . It's not a good candidate for check valve.
Just my experience .
#4 fallah
  • 5,026 posts
Posted 12 August 2022 - 11:33 PM
Yes, it's possible...the ball could be stuck at the top during normal flow then cannot prevent backflow in case of reverse flow...
