Flow Change With Delta P
flow delta p orifice flow rate pressure drop
#1 james.corrobro@gmail.com
  • 48 posts
Posted 15 August 2022 - 09:05 PM
If I have P1 at the inlet of pipe = 50 psig and P2 at end of pipe or destination based on pr. drop and flow is x for e.g.
Now if i put oriice plate in the pipe due to more delta P should not the flow increase to > x. ..since flow is propotional to delta P?
Why by putting orifice then  flow decrease???
  • 6,942 posts
Posted 15 August 2022 - 09:21 PM
You increase the head loss on the line (more resistance)  thus you modify your system curve , going to the left  .
