Are Defined Norms For Coefficients Of Discharge?
#1 SPCon
SPCon
Posted 22 August 2022 - 10:00 AM
I am in the process of designing an air sparge for a vessel. I have been trying to follow the method in Perry's. From what I have managed to piece together the Coefficient of discharge (C_d) is key to the calculations.
In the example in the book a value of 0.62 is used, but it is not stated where it came from. After further research I have found that it is possible to calculate a value for C_d, but to do this I would need to already know data such as the pressure drop though the hole and the hole area. But as these are values I am already trying to calculate i'm struggling to calculate the C_d.  So i'm wondering the C_d is defined within industry norms or something simlar.
Is anyone able to confirm if this is the case? or does anyone know what I'm missing?
thanks in advance
  • 1,639 posts
Posted 22 August 2022 - 11:46 AM
Review the topic previously covered in this forum at https://www.cheresou...stributor-pipe/
The Knaebel reference has been particularly useful to me.
The Cd is an experimental value for different discharge configurations and usually grabbed from a table for calcs as 'good enough'.
#3 Bobby Strain
Posted 22 August 2022 - 12:50 PM
You should consider buying from a company who manufacturers sparge mixers. You won't get very effective mixing with only holes in a pipe.
#4 breizh
  • 6,942 posts
Posted 22 August 2022 - 07:14 PM
Consider the docs attached to support your work.
In some papers I found  a Cd value of 0.61 to 0.62 .
#5 latexman
  • 1,894 posts
Posted 23 August 2022 - 07:27 AM
SPCon,
There are some "tables" here.  I suspect the orifice discharge coefficients are closest to what you are doing.  Google "list of discharge coefficients".  It will be helpful to you.
#6 SPCon
SPCon
Posted 24 August 2022 - 02:43 AM
thanks for the help all. I think I have enough information to proceed.
