Industrial Butane Bullet
#1 ccameron
ccameron
Posted 24 August 2022 - 11:11 AM
Hello all,
I have a butane bullet used for some gas blending. There's some points in the year, especially in the winter where we have problems keeping pressure high enough to provide decent suction pressure on a pump that pushes the butane down the line to our blending area. Our NPSHa drops below required and will pose the risk of cavitating our pump. If we could somehow find a way to put a blanket of nitrogen or fuel gas in this bullet we could maintain pressure on demand all year around.
My question is does anyone have experience putting a blanked on a LPG bullet system? haven't really seen anything online regarding this. I'm assuming with a blanket system on an already semi pressurized system, we would need a PVRV to automatically vent excess nitrogen when pressure goes above a set point. But we have butane vapor that's mixed in with that nitrogen and it would probably start becoming a safety concern. Maybe we can send that to flare.
Thanks in advance for any advice!
  • 1,623 posts
Posted 24 August 2022 - 12:06 PM
Consider a heat exchanger to add heat to a recirculating butane stream.
#3 Bobby Strain
Posted 24 August 2022 - 12:38 PM
The NPSHA does not change with bullet pressure! Maybe you have a head problem; maybe not.
#4 Chemitofreak
Chemitofreak
  • 292 posts
Posted 26 August 2022 - 02:57 AM
I agree with bobby, NPSH for a boiling liquid should not change with ambient temperature unless there huge pressure drop in the suction piping.
btw, what type of pump you have in your facility?
