Maximum Allowable Concentration Of H2S
#1 z_z
z_z
Posted 16 September 2022 - 08:40 AM
- What is the maximum allowable concentration of H2S while using SS 316?
- What is the maximum allowable concentration of H2S while using A106?
- Incase of high H2S concentration (200+ ppm), what material is recommended to be used to transfer the sour gas (pipe, Fitting and Valve)?
Hopefully that makes sense, any recommendations is much appreciated.
Zee
  • 1,635 posts
Posted 16 September 2022 - 11:57 AM
What have you found in your internet search so far? I see 600 million search hits for 'steel h2s' with several relevant articles at the top of the list.
#3 seuenergy
seuenergy
  • 40 posts
Posted 20 September 2022 - 12:39 AM
There is big difference of corrosion performance in dry H2S and wet H2S.
First you need to confirm whether water exist.
Then you contact engineering department for proper material.
#4 shvet1
shvet1
  • 476 posts
Posted 07 October 2022 - 12:59 AM
There is no a simple answer. Depends on industry, equipment type and process conditions. See NACE MR0175, NACE RP0296, NACE MR0103, ISO 15156, ISO 17945 for a general guide.
Edited by shvet1, 07 October 2022 - 01:02 AM.
