Variable Speed Pumps Operation.
vsd flowrate pump discharge pressure
#1 panoska
panoska
  • 321 posts
Posted 11 October 2022 - 11:42 AM
Hello engineers!
I was trying to understand how the variable speed pump works!
And then a new doubt was created, which is very fundamental.
A pump increases the flowrate in a system or the pressure?
Why increase in the speed of the pump increases the flowrate of the pump?
There are so many different opinions in Google. But, I would love to hear your opinion and understanding on this basic fundamental knowledge.
Edited by panagiotis, 11 October 2022 - 02:06 PM.
  • 6,940 posts
Posted 11 October 2022 - 06:23 PM
Let you study these documents and also pump's curves @ different RPM.
Centrifugal Pump converts kinetic energy to movement thus flow.
#3 panoska
panoska
  • 321 posts
Posted 12 October 2022 - 05:20 PM
Hi Breizh,
Thanks for sharing these documents with me.
#4 ali99
ali99
  • 14 posts
Posted 03 December 2022 - 05:31 PM
Good morning / evening Gents,
could you please resend the document, it will be useful for me.
Thanks.
#5 breizh
  • 6,940 posts
Posted 03 December 2022 - 06:31 PM
Document attached
#6 ali99
ali99
  • 14 posts
Posted 03 December 2022 - 06:56 PM
Hi Breizh,
#7 StealthProg
StealthProg
  • 74 posts
Posted 04 December 2022 - 01:04 PM
Increasing centrifugal pump speed increases the pressure, which overcomes the pressure drop in the pipework and therefore increases flowrate, pressure drop is proportional to V^2.  You have to remove the flow control valve for a variable speed drive to work (or leave it fully open).  When the flow control valve is in place with a fixed speed pump, some of the energy is wasted and increases the enthalpy (temperature) of the fluid.  The flow/pressure drop relationship is balance by the valve opening wheaeas with a variable speed drive it's balanced by the speed of the pump.
