Minimum Vapour Headspace For N2 Blanketing
#1 go-fish
go-fish
  • 189 posts
Posted 07 January 2023 - 09:08 AM
I am reviewing the vendor proposal for a non-metallic chemical storage tank for storing diluted KOH. The vendor has provided only 200 mm top freeboard above the working liquid level. It seems low to me. The tank has nitrogen blanketing to prevent any oxygen/CO2 ingress. Is there a minimum head space requirement for proper N2 padding?
The slosh wave height due to seismic factors is not significant. So that's not a factor in determining the freeboard height.
#2 latexman
  • 1,893 posts
Posted 07 January 2023 - 09:46 AM
API 2350 is probably not applicable to you for several reasons, but it is somewhat relevant.  Google it up or click the link below:
API 2350
#3 Pilesar
  • 1,635 posts
Posted 07 January 2023 - 02:01 PM
As far as I know, nitrogen blanketing requires only a vapor space. Pressure changes would be more rapid with a small vapor volume. Overfill would be my concern also since there is not much allowance for level measurement inaccuracies. Sizing liquid storage to allow 10% vapor volume would be my first inclination to have a reasonable design margin.
#4 breizh
  • 6,939 posts
Posted 08 January 2023 - 02:24 AM
You may find pointers in the link attached:
https://www.scienced...123725066000150
Good luck,
#5 horatorres
horatorres
  • 88 posts
Posted 08 January 2023 - 07:41 AM
Al least 30 plg for liquid storage from upper level measurement nozzle.
Horacio
#6 go-fish
go-fish
  • 189 posts
Posted 09 January 2023 - 08:29 AM
Horacio
30 plg? Sorry please can you elaborate
