Exchanger Design And Rating (Edr) In Aspen Plus
Started by panoska, Mar 12 2023 02:43 AM
Posted 12 March 2023 - 02:43 AM
I would like to ask you if there is any shortcut method in EDR, which can calculate the area of my heat exchanger if I dont have information about the heat transfer coeffecients?
Thank you in advance!
Posted 12 March 2023 - 08:30 PM
The heat transfer coefficients are dependent upon the heat exchanger design. EDR provides the calculated heat transfer coefficients in the program output. If you want a shortcut, then look up typical overall heat transfer coefficients for your streams as compiled by others and calculate the area from that.
Posted 13 March 2023 - 04:59 AM
Consider these resources:
On-Line Heat Exchanger Sizing (freecalc.com)
http://www.engineeri...ng/thermal.html
Posted 13 March 2023 - 02:54 PM
Thank you both for your replies! ????
Selection Of Heat Exchanger For Heating LiquidStarted by Guest_fahctory_* , Yesterday, 09:04 AM |
Lng ExchangerStarted by Guest_guoyinyanliner_* , 10 Feb 2026 |
Best Heat Exchanger Type For Gas HeatingStarted by Guest_Gole_* , 29 Jan 2024 |
