hi,
i have simulation cryogenic distillation with aspen hysys. at the and when i want to run it doest work. can anyone help me?
thank you
Posted 14 March 2023 - 08:56 AM
hi,
thank you
Posted 14 March 2023 - 09:12 AM
You've overspecified the exchangers and underspecified the columns.
Posted 14 March 2023 - 09:21 AM
are my heat exchanger too much and my column data is not complete? could you tell me which heat exchanger I had to remove?
thank you
Edited by xyadap, 14 March 2023 - 09:25 AM.
