Calculating Mass Flow Rate In Heat Pump
heat pump mass flow rate
#1 rednaxela
rednaxela
Posted 16 March 2023 - 09:36 AM
I am trying to calculate the mass flow rate of water (m) in a heat pump cycle. I currently have the power output required (200 kW) , temperatures (T1 = 20degC, T2 = 80degC) and enthalpies for the system (h1, h2, h3 & h4 - can provide). From what I understand m = power/(heat capacity * deltaT), however I am struggling to implement these values to obtain a mass flow rate.
I would be very grateful for any tips you can provide! Also, I can provide more information if required.
Many thanks in advance
  • 6,940 posts
Posted 16 March 2023 - 08:42 PM
HI,
Share with us your work and show us your difficulties.
You should use a Mollier diagram to visualize the process and get access to data ,then mass and heat balances to perform around evaporator and condenser, condenser and other valve.
https://energyeducat...ning into a gas.
Underneath a link to get access to thermophysical data:
https://webbook.nist...hemistry/fluid/
