Diesel Composition For Hx Design
diesel composition heat exchanger
#1 ganeshrbhat
ganeshrbhat
  • 5 posts
Posted 05 May 2023 - 08:57 AM
Dear Members,
I am trying to design a heat exchanger for cooling diesel. To determine the thermo-physical properties, I need a typical diesel composition. Appreciate if someone could please share a typical diesel composition that will help me design my heat exchanger.
Thanks in advance.
Ganesh
#2 Vegeta
Vegeta
  • 133 posts
Posted 05 May 2023 - 03:52 PM
You may use a distillation curve of diesel (e.g. ASTM D86) to estimate the properties in a process simulator
#3 ganeshrbhat
ganeshrbhat
  • 5 posts
Posted 05 May 2023 - 04:23 PM
Hi All,
If I get the composition of a diesel cut then using simulation tools the properties can be determined. I am not able to get the composition of diesel. Hence the request.
#4 Pilesar
  • 1,637 posts
Posted 05 May 2023 - 04:30 PM
Some standard diesel composition info can be found here:  https://www.iea-amf....iesel_gasoline/
