Cryogenic Separation Of Steam Reforming Syngas
aspen cryogenic distillation distillaton steam reforming separation
12 replies to this topic
#1 Fjm989898
Fjm989898
  • 5 posts
Posted 15 May 2023 - 07:57 AM
Hello im having trouble trying to design a system that can be used to separate the syngas products of steam reforming
the gas stream contain CO2, H2, N2 and O2 . and trying to separate each gas  into an individual stream.
i had tried using MDEAmine to remove CO2 in an absorption column and cryogenic distillation column to Separate the other gases CO2,O2,H2 . Any help in generating an aspen file is appreciated for the process is appreciated. Mass flowrate  is 9139kg/hr with compositions CO2 47.65%,H2 7.43%, N2 38.91%,O2 6.01%
  • 1,645 posts
Posted 15 May 2023 - 08:32 AM
More description would help. Is your composition on mass basis or mole basis? Where did the oxygen come from? Is this supposed to mimic some commercial process?
#3 seuenergy
seuenergy
  • 40 posts
Posted 15 May 2023 - 10:15 AM
It is my first time to see syngas with both high concentration of H2 and O2. why the O2 concentration is so high?
#4 Pilesar
  • 1,645 posts
Posted 15 May 2023 - 01:37 PM
See if the SEP unit op in AspenPlus will be good enough for your CO2 separation. You give the unit spec on how much CO2 remains and set the temperature and pressure of the vapor outlet. You should know the answer you want out of the amine absorber and the SEP unit can give you that answer without trying to converge a distillation column. You will then need to add water to the model to saturate the vapor which leaves the amine solution so you may need to add a dryer to your process. Cryogenic distillation is not recommended for your process. Maybe a membrane unit would be better for separating the hydrogen. The oxygen/nitrogen product has little value so vent that stream without further separation. Model the amine system for sizing after your initial material balance is complete. [And do confirm you really have oxygen in the feed and get rid of it before further processing.]
#5 Bobby Strain
Posted 15 May 2023 - 04:02 PM
Start at the beginning. From what process does this syngas originate?
#6 Nikolay_
Nikolay_
  • 169 posts
Posted 16 May 2023 - 07:21 PM
Oxygen is degraded MDEA.
#7 Fjm989898
Fjm989898
  • 5 posts
Posted 17 May 2023 - 04:39 AM
the Composition is mass based. its based on Partial oxidation of methane. its for a school project that involves design of a Urea plant using the Snamprogetti process .With Hydrogen coming from steam reforming Methane
#8 Fjm989898
Fjm989898
  • 5 posts
Posted 17 May 2023 - 04:52 AM
the purpose of the reforming was to make hydrogen for ammonia synthesis that is why the concentration is high and the O2 concentration is high due to the fact that balances were done for partial oxidation steam reforming so excess air was added as well to provide N2 as a source of N2 as well in the process
#9 SilverShaded
SilverShaded
  • 237 posts
Posted 17 May 2023 - 05:12 AM
It seems counterintuitive to have partial oxidation and an excess of O2?
#10 Pilesar
  • 1,645 posts
Posted 17 May 2023 - 05:27 AM
Air is usually added in such a process immediately after the steam reformer at a high temperature over catalyst where the oxygen reacts to completion. You should be able to find online descriptions and material balances for the ammonia process.
#11 Fjm989898
Fjm989898
  • 5 posts
Posted 17 May 2023 - 08:57 AM
hmm thank you that is quite an eye opener i think an absorber works for the CO2 and would it be advisable to say use of a palladium absorber rto remove the hydrogen from the stream. the main issue here being that the nitrogen i had stated in my problem statement to my supervisor that the nitrogen will be sent to the ammonia plant this is for a design problem for school for production of urea fertiliser with methane reforming providing the hydrogen.
#12 Pilesar
  • 1,645 posts
Posted 17 May 2023 - 12:51 PM
There is no reason to separate the H2 from the N2 since they will be reactants in the same reactor. Just get the proportions of nitrogen and hydrogen correct and send the stream to the reactor loop after removing the other components. There should be no elemental oxygen as it will all be reacted to CO or CO2 or H2O. Convert the CO to CO2 then remove the CO2 with an amine system. Convert any remaining CO and CO2 to CH4. For student work, an aqueous MEA system will be easiest to model for CO2 removal. Here is a diagram showing the main reaction units for the ammonia process: https://image.slides...eets-2-2048.jpg There is plenty of references inside the internet on the ammonia process. Snam urea process has flowsheets also. You can try to reinvent these processes but you will likely run into dead ends. The Haber-Bosch ammonia process is over 100 years old and quite reliable.
#13 reactwell
reactwell
Posted 22 May 2023 - 02:27 PM
What is your flow rate? Typically for separation of gases, there are smaller use cases with pressure swing adsorbers (PSA) that utilize an adsorbent and then there are the cryogenic separation units for higher flow rates, when the PSA units can't keep-up.
This should be a first consideration unless your required to use the cryogenic unit operation.
