Restricted Orifice (Ro) After The Reciprocating Compressor? Why?
#1 VolereePotere
VolereePotere
Posted 24 May 2023 - 03:50 AM
I saw in one of our P&ID that there is a Restricted Orifice (RO) after the cylnder of the reciprocating compressor (used for pressurizing the natural gas). As a beginner, I m confused about the usage of the RO. We use the compressor to increase the pressure of the natural gas but RO is intended to cause permanent pressure loss? What could be the reason to use RO there?
Sorry for not sharing all the process. After the RO, natural gas leads to the cooler.
I would be grateful if you could answer my question.
Thank you in advance.
  • 6,894 posts
Posted 24 May 2023 - 04:46 AM
It has to do with pulsation, dampener effect. You may need to contact the manufacturer or vendor of the unit to get more information.
https://journals.sag...ilar-articles.3
You may want to use your favorite search engine to get some info.
#3 shvet1
shvet1
  • 476 posts
Posted 24 May 2023 - 05:25 AM
Or limiting the capacity of a PSV at suction side
#4 VolereePotere
VolereePotere
Posted 24 May 2023 - 07:20 AM
Thank you for the quick responses:)
#5 krishnasagar.atluri
krishnasagar.atluri
  • 7 posts
Posted 03 February 2025 - 09:15 AM
Yes, during the initial phase of engineering, Vendor proposes these orifices on the suction and discharge side of the compressor with a HOLD. Usually if we see from mechanical point of view, the pulsation dampeners are a long lead item and based on Approach 1 study vendor will do the preliminary sizing of these vessels as per the criteria stated in API 618. Once the project matures, vendor performs the Approach 2 or 3 studies (as per project requirements) and will confirm the requirement of orifices on the suction and discharge side to limit the pulsation levels as per the code.
