Too Low Heat Exhange Area?
heat recovery heat exchanger combustion gases
#1 IngenieroJuan
IngenieroJuan
Posted 28 May 2023 - 03:15 PM
Hello!,
I'm designing a shell and tubes heat exchanger for the recovery of 2210 thermal kW from hot flue gases, so i can heat production water for an ORC. Gas from 594.4 to 105 °C and water from 75 to 102°C. Heat transfer area required is just around 1.4m2 for this service, which i double checked just to be sure the result is correct.
Does this result make any sense?
I don't have any reference system on which i can verify if this heat exchanger is appropriate.
Thank you!
#2 Bobby Strain
Posted 28 May 2023 - 03:59 PM
Doesn't look even close. Show your calculations. Maybe someone will help you.
#3 breizh
  • 6,913 posts
Posted 28 May 2023 - 07:15 PM
Share your calculation and/or at least provide sufficient information for us to help you.
Pay attention to the risk of corrosion during condensation process.
A reference attached.
#4 Padmakar Katre
Padmakar Katre
  • 992 posts
Posted 09 June 2023 - 04:51 AM
Hello!,
Thank you!
With this much information, I can do some rough estimates,
1. Q = 2210 kW
2. LMTD = 165.4 deg C
3. U = assuming flue gas side governs the overall heat transfer coeff, assumed 100 kcal/h-m2-C
4. Area = 115 m2.
#5 horatorres
horatorres
  • 88 posts
Posted 11 June 2023 - 09:01 PM
Check the calculations, the mt2 is too low.. Look for Kern´s book if you don have a simulator available to use
horacio
