Reg: Side Strippers
Posted 18 June 2023 - 09:05 PM
I have observed in some side strippers of CDU columns.
Both Direct steam and reboiler is given for Swing Naphtha/ Light kerosene/Heavy Kerosene side cuts strippers and only direct steam provision for Light Gas Oil and Heavy Gas Oil side strippers.
Q2. What will be the issue if only reboiler provision is given for Light kerosene side stripper without direct steam provision? Or only direct Steam provision instead of reboiler?
Kindly guide.
Posted 20 June 2023 - 03:07 AM
Q1: Optimum rate of return by calculating cost of products and capex&opex of CDU. Note that some operators even use for stripping hydrogen instead of steam. All depends on money and availability of sources. For cases such complexity Aspen1 has dedicated utilities providing a prompt prediction of opex&capex of a process unit.
Q2:
Reboiling only - overduty of kero trim cooler
Stripping only - kero contamination by water
Advise - check temperatures in a side stripper and a relevant section of a fractionator - maybe temperature is not high enough to guarantee water condensation does not occur. Depends on local water partial pressure. Free water is allowed only in condenser stage.
Edited by shvet1, 20 June 2023 - 03:10 AM.
Steam On Shell Side Of A Vertical HexStarted by Guest_Lyne_* , 09 Jul 2025 |
Side Stripper Vs Separate ColumnStarted by Guest_waheed2020_* , 13 Jan 2024 |
Current Operating Pressure 95 Psig In Shell Side Of Shell-Tube He AndStarted by Guest_Hafiz_Che_* , 09 Dec 2023 |
![]() Hx Psv Sizing: Tube Side Fire Case With Shell Side Being Steam.Started by Guest_tamueng_* , 07 Nov 2023 |
![]() ![]() Flare Seal Drum Blowing Seal Water To Other Side Of Baffle- Loosing SeStarted by Guest_Shamsi_* , 13 Sep 2023 |
