Sulphuric Acid & Water Mixing Heats. Is It A Typo Error
heat of mixing h2so4
7 replies to this topic
#1 IonCube
IonCube
  • 62 posts
Posted 24 June 2023 - 06:16 AM
I am attaching x2 pages from a book in which mixing & exothermic heats encountered is given as an example. I believe there is an error in calculation which I have annotated in pdf. Can anyone review?
  • 6,940 posts
Posted 24 June 2023 - 06:40 AM
You may want to use the document attached to review your calculation.
#3 IonCube
IonCube
  • 62 posts
Posted 24 June 2023 - 07:10 AM
@breizh
Thanks, I know the calculation but the procedure I am understanding. The procedure is straightforward & if my understanding is correct there is a typo error in calculation. I just want someone to review it
#4 breizh
  • 6,940 posts
Posted 24 June 2023 - 07:43 AM
Yes there is a Typo , you should read -110 Btu/lb.
#5 IonCube
IonCube
  • 62 posts
Posted 24 June 2023 - 07:50 AM
@breizh
Thank you, your time meant a lot for me. Thanks again
#6 gigrosia
gigrosia
Posted 26 June 2023 - 07:00 AM
@breizh
Calculate the heat, Q, that needs to be transferred to return the mixture to 77 оF
Mixture - 60% w/w H2SO4
enthalpy 60% H2SO4 at 144 oF - (-86)
enthalpy 60% H2SO4 at 77 oF -(-121)
Were is the error?
#7 breizh
  • 6,940 posts
Posted 26 June 2023 - 07:21 AM
No error on the textbook. The confusion comes from the OP showing a 50% solution on the graph instead of 60%. My bad.
Sorry about that.
Another brochure to support (page 13). example with dilution with water.
#8 IonCube
IonCube
  • 62 posts
Posted 27 June 2023 - 09:24 AM
@breizh
Were is the error?
Thanks for correcting us. So if I explain it in words: The 60% solution [the final product via mass balance] is assumed to be adiabatically heated [heat comes from dilution] from 77F to 144F
Edited by IonCube, 27 June 2023 - 09:28 AM.
