Material Balancing
#1 IluvChem
IluvChem
Posted 10 July 2023 - 03:46 PM
Silicon tetrachloride (SiCl4, aka tetrachlorosilane) reacts with magnesium metal (Mg) to make pure solid silicon and magnesium chloride (MgCl2). A researcher runs a continuous flow reactor that is fed a mixture containing 84.2 wt-% SiCl4 and 15.8 wt-% Mg at a rate of 303 g/h. The reactor exit stream contains only Si, MgCl2, and SiCl4. Solve for all variables in this system.
SiCl4 + 2Mg ------> Si(s) + 2MgCl2
1.What is the flow rate (g/hr) of magnesium chloride in the outlet stream?
2.What is the weight percent of magnesium chloride in the outlet stream?
  • 6,371 posts
Posted 10 July 2023 - 06:56 PM
We don't do homework, but we are happy to help. Show us your work and tell us your difficulties.
Hope you understand.
Mass in=Mass Out,
Mass balance on species to be performed,
Molecular weight of each species to be calculated,
etc.
To ease the calculation, I get use to work on 100 g basis,
Create an excel sheet to perform your calculation and communicate with us.
note: Check the given data versus the chemical reaction, you may have a deficit of reactants.!
answer 1   187.5388 g/h MgCl2           answer 2   61.89401 % MgCl2
