Multiple Effect Evaporation
multiple effect evaporation ethanol ethylene
9 replies to this topic
#1 Quimarah
Quimarah
  • 21 posts
Posted 15 July 2023 - 10:16 AM
Hello everyone!
Im starting my thesis work about direct hydration of ethylene for the industrial production of ethanol. We based our separation system on a train of distillation columns (3 columns). Then we used glycerol as entrainer in the azeotropic dehydration.
The thing is that this columns are conected from the top (which is uncommon in the industry).
Our tutor suggested that we implement a multiple effect evaporation due to the large amount of water.
Is this possible in our process? How is the right way to approach this change?
We are using ASPEN HYSYS v8 for the simulation.
Thanks in advance
Evelyn
  • 6,939 posts
Posted 15 July 2023 - 08:43 PM
Can you share with us a simple PFD to better visualize your process?
#3 Quimarah
Quimarah
  • 21 posts
Posted 16 July 2023 - 12:29 PM
Hello! yes!
This is the train of distillation columns.
#4 breizh
  • 6,939 posts
Posted 16 July 2023 - 08:04 PM
Thanks for sharing this document. I was expecting a simplified process schematic where we can see the evaporators.
Anyway, I've attached a few documents about Multiple effects evaporators and MVR technology.
Hope this helps you.
Probably others can help you on Aspen and process parts.
#5 Quimarah
Quimarah
  • 21 posts
Posted 17 July 2023 - 08:56 AM
Thank you!
#6 shvet1
shvet1
  • 476 posts
Posted 18 July 2023 - 12:27 AM
a disputable point
yes, it is
To model possible options and choose one having best investment return rate. Easy and fast way for first approach to process development.
v12+ is recommended as it provides built-in features for capex and opex assessment.
Edited by shvet1, 18 July 2023 - 12:30 AM.
#7 Quimarah
Quimarah
  • 21 posts
Posted 19 July 2023 - 07:49 AM
Thank you for your answer shvet1. Is this process of multi-effect evaporation in the model pallete or do we have to simulate in other ways?
#8 shvet1
shvet1
  • 476 posts
Posted 19 July 2023 - 09:20 AM
I did not understand.
#9 breizh
  • 6,939 posts
Posted 19 July 2023 - 09:50 PM
Let you Google: multiple effects evaporators model aspen
you will find examples , combination of heaters, separators , mixers .
https://core.ac.uk/d...f/163104933.pdf
Similarly RMV is one heater , one separator and one compressor and mixers.
#10 Quimarah
Quimarah
  • 21 posts
Posted 21 July 2023 - 04:35 PM
Thank you for your help!
