Truck Loadings
12 replies to this topic
#1 panoska
panoska
  • 319 posts
Posted 20 July 2023 - 02:38 PM
Hello everyone,
I would like to ask you if there are typical flowrates loading to trucks?
Thank you in advance!
#2 Bobby Strain
Posted 20 July 2023 - 03:27 PM
Check with your trucking company. It will depend on what material you are handling.
#3 latexman
  • 1,856 posts
Posted 20 July 2023 - 07:06 PM
In my experience, a flow rate of about 100 U.S. gpm is typical for loading and unloading tank trucks. This give a tank truck load/unload time of about 1 hour.
#4 breizh
  • 6,838 posts
Posted 20 July 2023 - 09:07 PM
My experience on this matter, I've seen companies using meters to unload their trucks, others were using truck scale to invoice their customers. To me the flow rate depends on the specificity of the product and the accuracy required to fill in your capacity.
#5 fallah
  • 5,025 posts
Posted 22 July 2023 - 04:36 AM
Typical fluid velocity for loading is average 2 m/s and maximum 3 m/s. You can calculate the typical flow rate based on the pipe size...
#6 breizh
  • 6,838 posts
Posted 22 July 2023 - 05:27 AM
Hi Nasser,panagiotis,
Need to be cautious here, it depends very much on the product, flammability, static electricity risk.
https://www.pcimag.c...oadingunloading
#7 fallah
  • 5,025 posts
Posted 22 July 2023 - 05:50 AM
Hi Breizh,
Ok, such parameters should also be considered in specifying the flow rate...for loading...
#8 panoska
panoska
  • 319 posts
Posted 22 July 2023 - 11:04 AM
Hi everyone,
Thank you for your replies. 3 m/sis a quite general velocity criterion, right?
#9 breizh
  • 6,838 posts
Posted 22 July 2023 - 06:45 PM
Is this an academic work?
We have no idea about the product.  Truck loading is not a simple operation, check MSDS of the product and forget about simple criteria.
https://www.chevronw...on_from_CBT.pdf
#10 shvet1
shvet1
  • 476 posts
Posted 23 July 2023 - 11:04 PM
Hi everyone,
No. Depends on loading arm, track vessel, product, vapor recovery and many other things. describe in detail your case to provide a valuable response.
More details = better answers
Edited by shvet1, 23 July 2023 - 11:05 PM.
#11 panoska
panoska
  • 319 posts
Posted 24 July 2023 - 11:38 PM
Hi it is not an academic work.
The mixture consists of some prepolymers.
Your answers are helpful enough. All of you gave me a good insight. ????
#12 breizh
  • 6,838 posts
Posted 25 July 2023 - 12:41 AM
OK, the reason why it's important to check for static electricity.
velocity max 1m/s,
Some companies are using chemicals (ppm) to mitigate the risk. I had this requirement from a company in Australia where we were supplying resins (polymers).
https://polymer-addi...ts-for-polymers
#13 panoska
panoska
  • 319 posts
Posted 25 July 2023 - 06:15 AM
Ok thank you Breuzh, I will take your advice into account. ????
