Edited by Said Salim, 31 July 2023 - 04:06 AM.
Low Pressure Co2 Cooling Heat Exchanger Selection
Started by Said Salim, Jul 25 2023 11:14 AM
Posted 25 July 2023 - 11:14 AM
Hi All,
We intend to cool CO2 compressor suction stream of around 95000 KG/H from around 55 DegC to 44 DegC using chilled water of a temperature ranges between 5 DegC to 12 DegC. However, our CO2 suction stream pressure is as low as 0.985 Barg and by introducing the cooling unit this pressure will be reduced further.
My enquiry is what is the most suitable exchanger type for our application i.e. maintaining minimum pressure drop across the exchanger.And can this exchanger be modeled in either Aspen EDR or HTRI?
SAID
Posted 26 July 2023 - 11:57 PM
Doublepipe can provide the same dP as suction pipe does and even a bit less if lower roughness of hot side will be provided. Aspen EDR and HTRI are both available to model that. Note that cost&wieght will be significant comparing to heat exchangers with conventional design.
Edited by shvet1, 27 July 2023 - 12:28 AM.
Shell And Tube Pressure DropStarted by Guest_UofUChemE_* , 08 Jun 2018 |
Screening Heat & Material Balances Cases For Fire Relief Psv SizinStarted by Guest_powerox6_* , 21 Aug 2026 |
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
