As part of a modular plant installation, I will need to hire a contractor to study the impact of the new plant to the existing flare system. I have 5 new pumps that use API-52/11 seal plans that will vent to the flare. Do flare studies typically include seal pot vents? Are these flows typically so low that they are considered negligible for the purpose of a flare study? If not, how do I estimate a "normal" vent rate and a "worst case" vent rate? Thank you for your help.
Flare Study And Pump Seals
Started by Sue N, Aug 21 2023 12:52 PM
Posted 21 August 2023 - 12:52 PM
Posted 28 August 2023 - 03:41 PM
Experience says this is negligible, but we don't know the size of the existing facilities, nor the flare system size.
It should be easy to check by comparing nominal seal venting rates vs. flare capacity. I'd expect to see a difference of several orders of magnitude.
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
Vacuum PumpStarted by Guest_R.t_* , 19 Sep 2025 |
Want Api For StudyStarted by Guest_garv_* , 15 Aug 2025 |
