How To Calculate Half-Time Of Reaction
half-time second order varible-volume constant pressure
#1 chemtoli
chemtoli
  • 33 posts
Posted 22 August 2023 - 07:31 AM
For this type of reaction (second order reaction in a constant pressure-variable volume batch reactor)
A+B -->C
at T=23°C, we have k= 0.1615 L /mol*min  and CA0=CB0= 0.016 mol/L
Calculate the half-time of the reaction (t1/2) and the rate of conversion of reactant, A (XA) after 100 minutes.
What is the equation for half-time of the reaction (t1/2)
  • 6,940 posts
Posted 22 August 2023 - 07:49 AM
The half-life of a reaction is the time required for the reactant concentration to decrease to one-half its initial value.
​Share with us your work, someone will comment.
#3 chemtoli
chemtoli
  • 33 posts
Posted 22 August 2023 - 10:08 AM
hi breizh,
based on the data from the Book of GAVHANE, I have reached this point (see the attachment). But now I don't know how to calculate the half life of the reaction and the rate of conversion of reactant A, after 100 minutes.
#4 breizh
  • 6,940 posts
Posted 22 August 2023 - 10:38 AM
hi, come on!
-ra=k CA^2=-dCA/dt
perform the integration between the limits, t & to=0 with the respective concentration CA and CA0.
#5 chemtoli
chemtoli
  • 33 posts
Posted 22 August 2023 - 11:08 AM
can this equation be applied to the case when reaction is second order in a constant pressure-variable volume batch reactor.
t1/2=(1/k)*[(1/CA)-(1/CA0)]
what is value of Cand how to find XA
Edited by chemtoli, 22 August 2023 - 12:04 PM.
#6 breizh
  • 6,940 posts
Posted 22 August 2023 - 06:14 PM   Best Answer
You seem not having a proper method to solve problems.
You should assess first the data available, secondly establish the general equation and finally apply it to particular cases (questions 1 and 2).
Get the general equation: t = function (Ca, Cao, k) and then play around for your particular cases.
1) t1/2 should be 387 '
2) XA=0.205
#7 chemtoli
chemtoli
  • 33 posts
Posted 23 August 2023 - 01:30 PM
thank you so much breizh
