Cases For Liquid Psv Relief
#1 Aiman061000
Aiman061000
Posted 01 November 2023 - 07:59 PM
I'm currently sizing a PSV for liquid relief. In brief, the discharge side of a progressive cavity pump has a tee connection which branches to a spillback line equipped with a PSV. The PSV will dispose the relief liquid back at the pump suction line.
What are the example of relief cases based on this design, and which one should be the governing one?
Thanks,
Aiman
#2 Bobby Strain
Posted 01 November 2023 - 10:28 PM
You need to give much more information.
#3 fallah
  • 5,019 posts
Posted 02 November 2023 - 03:09 AM
Lack of adequate info...
But, in general, for such system you described the blocked outlet would be the relief case for mentioned PRV...
#4 Chemitofreak
Chemitofreak
  • 292 posts
Posted 09 November 2023 - 04:22 AM
Blocked outlet is most probably the governing scenario.
It is better to rout the relief valve outlet to the suction vessel instead of the suction piping.
