Saturated Water Boil
#1 Orzelgorskiego
Orzelgorskiego
  • 28 posts
Posted 12 November 2023 - 01:36 PM
We are building the heat exchanger for which we do not want use saturated steam.
Instead we want to use saturated water at 130deg.Machine will be certified by ASME.
Our question is whether is it possible to buy in USA water boiler which can heat saturated water above 100degC, desirable 130 to 150degC under corresponding pressure.
Thank you for help.
Tomasz
#2 Bobby Strain
Posted 12 November 2023 - 03:30 PM
It is not clear what you are asking.
#3 latexman
  • 1,893 posts
Posted 12 November 2023 - 06:24 PM
I would Google “industrial hot water heater” and see what you find.
Prepare a performance specification and send it to the vendors that look promising.
#4 breizh
  • 6,939 posts
Posted 12 November 2023 - 09:18 PM
As others said, difficult to understand the query. No information about the reason to use hot water instead of steam.
No sense in term of energy transfer. I guess it's related to the same technology for waste solid treatment.
 https://indeck.com/hot-water-boilers/
