Burning Or Explosion Of Calcium Phosphate Inside Water - Possible Caus
#1 Geetanjali
Geetanjali
  • 40 posts
Posted 17 November 2023 - 03:08 PM
Hi everyone,
I am aiming laser at the calcium phosphate material, submerged in water, to break it apart. I am observing some explosive burning type event (I see a spark) and possible formation of steam bubbles. The process results in charring/carbonization of the material at the end of experiment. I would appreciate if you could give your insight into the possible cause of this phenomenon. Not sure if it is the dissolved oxygen in the water that is leading to the explosion/spark generation.
Thank you,
Geetanjali
  • 1,635 posts
Posted 17 November 2023 - 09:07 PM
You do interesting work! Check whether there are hydroxides or oxides in your calcium phosphate material.
#3 Geetanjali
Geetanjali
  • 40 posts
Posted 18 November 2023 - 10:47 PM
Thank you Pilesar! :) I will check the presence of those oxides.
Best,
Geetanjali
#4 breizh
  • 6,937 posts
Posted 18 November 2023 - 11:58 PM
Did you try Google?
https://pubs.acs.org...021/ja01616a009
