Multiple Psvs Relief Rate
psv fire scenario
9 replies to this topic
#1 fmalik
fmalik
  • 9 posts
Posted 02 December 2023 - 12:11 PM
When adding multiple psvs to a vessel (fire case) is the total relief rate just divided by 2 in case the two psvs (same type) are added. API doesn't explicitly mention this therefore I wanted to confirm.
#2 latexman
  • 1,894 posts
Posted 02 December 2023 - 12:18 PM   Best Answer
Each does not have to be exactly half. But yes, the sum of the 2 PSV’s capacities must be >= the total relief rate. Both are required to relieve the vessel.
Some companies put a second PSV as an inline spare. In this case, each PSV’s capacity must be >= the total relief rate.
#3 fallah
  • 5,026 posts
Posted 03 December 2023 - 06:36 AM
When sizing for multiple valve applications, the total required area is calculated based on an overpressure of 16% or 4 psi, whichever is greater (for fire case 21%). Then two PSVs with the same size would be selected to cover the calculated total required area. Hence the relief loads of such two PSVs might or might not be equal.
Edited by fallah, 03 December 2023 - 07:37 AM.
#4 latexman
  • 1,894 posts
Posted 03 December 2023 - 07:06 AM
Under fire emergency conditions, pressure relief devices (1 or more) must be capable of preventing the vessel pressure from rising more than 21 percent above the MAWP.
#5 shvet1
shvet1
  • 476 posts
Posted 04 December 2023 - 12:02 AM
API allows 1st PSV 80 cfps capacity, 2nd PSV 20 cfps capacity while firecase relief is 90 cfps.
#6 latexman
  • 1,894 posts
Posted 04 December 2023 - 07:09 AM
cfps?  API # and section, please?
#7 latexman
  • 1,894 posts
Posted 04 December 2023 - 07:18 AM
API 520 Part 1 says:
Attached File  Capture 1.JPG   29.35KB   4 downloads
Attached File  Capture 2.JPG   64.04KB   2 downloads
#8 breizh
  • 6,942 posts
Posted 05 December 2023 - 12:25 AM
To add to the discussion, consider the documents from Lesser and from Crosby (with examples)
#9 shvet1
shvet1
  • 476 posts
Posted 11 December 2023 - 11:56 PM
Sorry for delay, I have been away from computer for a week.
cfps?
cfps = cubic feet per second
This is a reference to the statement you provided before
#10 latexman
  • 1,894 posts
Posted 12 December 2023 - 06:18 AM
Thx!
