Heat Of Reaction
#1 Guilhermexift
Guilhermexift
  • 4 posts
Posted 26 December 2023 - 12:21 PM
In a chlor-alkali plant sodium hypochlorite is produced by the following chemical reaction at 1 bar a:
Cl2 + 2NaOH --> NaClO + NaCl + H2O
That chemical reaction occurs inside an absorption tower and the reactants inlet condition is:
a) Caustic soda: 45°C / 18% wt (aqueous solution);
B) Chlorine: 70°C (gaseous);
c) I already know the heat of reaction at 25°C.
Sodium hypochlorite is very unstable and the product need to be cooled.
I need to estimate the heat of reaction at reactants condition and the outlet temperature of the products. My questions are:
a) Is it possible to estimate the heat of reaction without knowing the outlet temperature or vice versa?
B) I have to choose the outlet temperature that I want to keep the products and consider that?
c) If I already know the final temperature, how can I estimate the heat of reaction by specific heat integration? What temperature I consider as T1: 45°C, 70°C or an intermediate temperature between those values?
  • 6,940 posts
Posted 26 December 2023 - 07:44 PM
To my knowledge, you need to perform mass and heat balances along the column to get the height of the unit. You need to define a temperature within the column, it's an iterative calculation on dZ .
For sure you need an external heat exchanger to remove the excess of calories due to the reaction.
Note: Probably modern tools should help you out.
https://patents.goog...0050169832A1/en
