Back Pressure In Filters
9 replies to this topic
#1 panoska
panoska
  • 321 posts
Posted 22 January 2024 - 04:54 PM
Maybe the question is super basic! Sorry for that!
I am dealing with the term of backpressure during filtering process.
But, I am not 100% sure that I have fully understood the "concept" of backpressure. Could you please give some explanation about it?
Thank you in advance!
Edited by panagiotis, 22 January 2024 - 04:54 PM.
#2 Bobby Strain
Posted 22 January 2024 - 05:18 PM
So, what do you think it is?
#3 fallah
  • 5,026 posts
Posted 23 January 2024 - 02:00 AM
It simply is the pressure built up at filter upstream while filtering operation is in progress...
Edited by fallah, 24 January 2024 - 01:21 AM.
#4 latexman
  • 1,894 posts
Posted 23 January 2024 - 02:01 PM
It’s the upstream (pump discharge) pressure to push the filtrate through the filter at the desired flow rate.
#5 panoska
panoska
  • 321 posts
Posted 23 January 2024 - 03:41 PM
Thanks latexman for the very clear explanation.
Even though, I had done the hydraulic calculation. I could not realize where this term referred to.
I thought it was referring at the outlet of the filter.
#6 breizh
  • 6,940 posts
Posted 23 January 2024 - 09:00 PM
Take a look:
https://www.quora.co...ring filtration.
#7 panoska
panoska
  • 321 posts
Posted 24 January 2024 - 04:08 PM
Hi Breizh,
They give this definition in the link you sent me: "The restriction creates a pressure drop across the filter, known as the back-pressure."
#8 Bobby Strain
Posted 25 January 2024 - 12:48 PM
Some terms are ambiguous. So it's best to avoid using them. Words like biweekly.
#9 latexman
  • 1,894 posts
Posted 25 January 2024 - 03:14 PM
I agree with Bobby. To me, what makes more sense, à la PSV definitions, the back-pressure is on the pump discharge, which is caused by the pressure drop through the filter.
#10 panoska
panoska
  • 321 posts
Posted 25 January 2024 - 04:44 PM
Thanks all of your for your answer! Then, I did well that I asked you this "basic" question with the ambiguous interpretations!
