Variable Speed Pump Curves
10 replies to this topic
#1 panoska
panoska
  • 321 posts
Posted 27 January 2024 - 04:09 PM
Hello everyone,
I have a variable spèed pump and different pump curves for different frequences. Can my operating point be between two curves or it should be exacly on tbe curve?
Thank you in advance!
  • 6,940 posts
Posted 27 January 2024 - 04:33 PM
HI,
Yes ,of course. Affinity laws.
#3 panoska
panoska
  • 321 posts
Posted 27 January 2024 - 05:04 PM
Yes exactly! So my existing pump can operate at a "between" frequency!
#4 panoska
panoska
  • 321 posts
Posted 28 January 2024 - 04:28 AM
One further clarification to be sure:
If we assume a VSD pump with 5 different curves for 5 different frequences (800, 900, 1000, 1100 and 1200). Then the pump can operate in a middle frequence e.g between 900 and 1000 Hz, etc. ?
#5 breizh
  • 6,940 posts
Posted 28 January 2024 - 05:43 AM
What do you mean by 800 to 1200 Hz? where do you get these figures?
Instead of using a Control valve the VSD will adjust the frequency to the flowrate based on signal coming from the flow meter.
https://www.linkedin...ps-mark-nellist
#6 panoska
panoska
  • 321 posts
Posted 28 January 2024 - 04:02 PM
Hi Breizh,
Thanks for the further information. Please see the attached below to understand what I mean.
This is an existing VSD pump and the calculated point is between the two curves for the two different frequencies.
  • Attached File  VSD.jpg   60.54KB   2 downloads
#7 breizh
  • 6,940 posts
Posted 28 January 2024 - 09:10 PM
I've no question about what you mean except the data shared in a previous post (800 to 1200 Hz) which worried me. So far, no explanation!
Now regarding your picture, pay attention to the low HZ value and the risk to "burn" your motor if the RPM is not enough for the fan to cool the motor. Probably good for you to talk to an electrician within your organization about VSD best operating condition.
Good luck.
#8 panoska
panoska
  • 321 posts
Posted 29 January 2024 - 04:39 PM
Thanks Breizh for the reply. I lost you a bit in your last message!!
#9 latexman
  • 1,894 posts
Posted 29 January 2024 - 05:28 PM
Electric motors usually have fan blades attached to the shaft on the opposite side that drives the pump. This is to cool the electrical components that drive the motor. When a VFD slows the motor it also slows the fan which cools the motor, because they are on the same shaft. Most VFDs are set up for constant torque. To do this they increase voltage when they reduce frequency. At some low speed, the motor creates more heat than the fan can remove, and the motor “burns out”, but usually trips its thermal protection circuit.
#10 breizh
  • 6,940 posts
Posted 30 January 2024 - 12:09 AM
In other words, 30 Hz should be the minimum frequency to operate the pump.
#11 panoska
panoska
  • 321 posts
Posted 01 February 2024 - 03:57 PM
Thank you so much for the very informative answers, latexman and Breizh.
