Hi everyone,
I am using the in-built example of the carbon capture process by using K2CO3 in HYSYS v.14. I was trying to run the model by changing the feed gas composition and properties but after increasing the flow rate of the feed gas step by step, I failed to converge in regenerator. the error message is as follow:
Rating cannot be done because column COL1 with Tower Main Tower is not converged.
Rating cannot be done because column COL2 with Tower Main Tower is not converged.
* WARNING
PH COULD NOT BE CALCULATED (H+/OH- CONC TOO LOW OR MISSING).
* WARNING
* WARNING
* WARNING
Beginning Solution of Column Flowsheet Absorber
***** Generating RateSep Input *****
->Processing input specifications ...
->Executing
Block: ABSORBER
Convergence iterations:
OL ML IL Err/Tol
1 1 3 148.87
2 1 2 52.416
3 1 2 24.974
4 1 1 4.3952
5 1 1 0.19890
RateSep convergence iterations: ABSORBER
Iter Err/Tol
0 14583.
1 2401.5
2 656.85
3 25.297
4 0.36183
5 0.58613E-03
->Generating Results
Block: ABSORBER
Column Flowsheet Absorber Converged
* WARNING WHILE GENERATING REPORT FOR UNIT OPERATIONS BLOCK: "ABSORBER"
(MODEL: "RADFRAC") (PPTRUE.4)
Beginning Solution of Column Flowsheet Regenerator
->Executing
Block: REGEN
OL ML IL Err/Tol
1 1 10 6806.5
2 1 4 3296.2
* WARNING
MATERIAL AND ENERGY BALANCES FAILED TO CONVERGE: CHECK COL-SPECS
OR SUPPLY BETTER TEMPERATURE AND COMPOSITION ESTIMATES.
* WARNING
THE FOLLOWING STAGES DRIED UP:
1 3
A LIMIT OF 0.10000E-04 * SUM OF FEEDS WAS IMPOSED ON THE FLOW RATES.
* WARNING IN PHYSICAL PROPERTY SYSTEM
NEGATIVE VALUE OF LIQUID MIXTURE HEAT CAPACITY CALCULATED USING
PROPERTY METHOD ACID-GAS AT T= 225.39, P= 0.17027E+06
AN ABSOLUTE VALUE IS USED.
RateSep convergence iterations: REGEN
Iter Err/Tol
0 79549.
1 0.10341E+07
2 0.89891E+06
3 0.88934E+06
4 0.88685E+06
5 0.88685E+06
** ERROR
VARIABLE RESET ENCOUNTERED IN HOLDUP CORRELATION STICHLMAIR89.
THE PRESSURE DROP CALCULATION FAILED TO CONVERGE. THE CALCULATED
HOLDUP MIGHT BE WRONG. THE COLUMN DIAMETER MIGHT BE TOO SMALL.
** ERROR
RATESEP CALCULATIONS FAILED TO CONVERGE
ITERATIONS DIVERGE
* WARNING
UNUSUAL LIQUID MOLEFRAC PROFILE FOR COMP H2O N2.
PLEASE DOUBLE CHECK THE SOLUTION AND/OR ADJUST FLOW MODEL,
TRANSFER/REACTION CONDITION NUMBERS, PACKING HEIGHT/NSTAGE, ...
* WARNING
UNUSUAL INTERFACE LIQUID MOLEFRAC PROFILE FOR COMP N2 OH-.
* WARNING
UNUSUAL COMPONENT PRODUCTION PROFILE FOR COMP CO2.
* WARNING
UNUSUAL INTERFACE MASS TRANSFER PROFILE FOR COMP N2.
* WARNING
DESIGN SPEC IS NOT SATISFIED BECAUSE ONE OR MORE MANIPULATED
VARIABLE VIOLATED ITS BOUND.
* WARNING
PRESSURE DROP CALCULATION RESULTS MIGHT NOT BE ACCURATE
DUE TO VIOLATION OF CORRELATION LIMITS.
** ERROR
BLOCK H45.REGEN IS NOT IN MASS BALANCE:
MASS INLET FLOW = 0.62167626E+03, MASS OUTLET FLOW = 0.61721693E+03
RELATIVE DIFFERENCE = 0.72249046E-02
Error: Failed to solve the rate-based model!
Column Flowsheet Regenerator Not Converged
I hope someone can help me how to ease this issue?
thanks
