hi dear guys
in the our plant, when the gas separated of crude oil in the separators or tanks we have gas condensate too much in the gas lines. i know very well that main parameters is temprature difference between two points but i would like to know how do i reduce the gas condensate in the piping? do you think use of chemical injection? which is composition?
we have too much problem with gas condensate. if need to more data i'm ready and sent.
prosess data:
oil temp.:60oC
oil pressure:0.9-5bar in vessel & 40mbar in production tank
API:25
H2S, SALTY CRUDE OIL
Use of chemical injection like demulsifier, antifoam, oil & gas corrosion, asphaltene, h2s scavenger in the processing
thanks
