Reactive Distillation Mtbe
mtbe
#1 Michael Mitra
Michael Mitra
  • 3 posts
Posted 15 March 2024 - 02:44 AM
Hello! Help me please
Modeling Reactive Distillation MTBE. Column unconvergen. The column converges with Method: Modified Inside-out, but unconvergens with Method: Sparse Continuation Solver. Maybe someone has modeled Reactive Distillation and can tell me what settings to make in the basis and in Solver so that the column converges.
#2 Michael Mitra
Michael Mitra
  • 3 posts
Posted 15 March 2024 - 02:52 AM
Maybe tell me what specs are best to use?
#3 breizh
  • 6,939 posts
Posted 16 March 2024 - 12:16 AM
You may want to contact the tech support of  your application.
#4 Pilesar
  • 1,635 posts
Posted 16 March 2024 - 06:08 AM
Good column specs to use are 'bottoms rate' and 'reflux ratio'. As long as you have a converged run, then you can make changes in increments to get the results you want. There is no need to converge with more than one algorithm since the algorithm is just a path to the solution. Use the easy path when you find it!
#5 Michael Mitra
Michael Mitra
  • 3 posts
Posted 17 March 2024 - 09:15 PM
Thank you for your advice!
