Fired Heaters/ Burners/ Flue Velocity
flue velocity burners fired heaters heat transfer
#1 Lyne
Lyne
  • 60 posts
Posted 15 March 2024 - 03:53 AM
Hello everyone,
I'm doing a preliminary sizing for a direct fired heater using HTRI for a budget estimation and I am new to fired heaters design. I am studying the criteria for a fired heater design and i wanted to know how to determine the number of burners required ? how can I be sure that the tube circle diameters will fit all the burners ? also what's the flame length limit to avoid impingement ? HTRI also requires many parameters in the burner section that i didn't find much information about. I know that burners are left to vendors but any guidance from you is appreciated.
Thank you
#2 deft clay
deft clay
  • 19 posts
Posted 26 November 2024 - 09:08 PM
Hello. I have experience in fired heaters but not with HTRI xfh specifically and can give some rough answers to your questions. But first, since this was posted in March, did what have you found out since then?
#3 Lyne
Lyne
  • 60 posts
Posted 05 June 2025 - 01:50 AM
I used aspen EDR for the sizing instead of HTRI, it has a more friendly interface.
#4 deft clay
deft clay
  • 19 posts
Posted 11 June 2025 - 09:23 PM
Understood. Sounds like it was an early stage FEL study.
The burner details are necessary if you are building the heater yourself. If you are sizing it, verifying a vendor quote, etc, it's not needed.
