Valves On Low Pressure Steam Service
11 replies to this topic
#1 Ali4269278331
Ali4269278331
  • 31 posts
Posted 15 April 2024 - 02:27 PM
hi
i have a low pressure steam service as saturated that genrated of fire tube boiler. the steam temp. and pressure are 180oC and 8bar respectively. i want use of ball valve with charactrization that attached. which is Valve Item is good case for my design?
thanks
  • Attached File  88.pdf   97.06KB   31 downloads
  • 1,637 posts
Posted 15 April 2024 - 06:40 PM
Why do you want to use a ball valve? I suggest contacting your valve vendor for their recommendation.
#3 breizh
  • 6,941 posts
Posted 15 April 2024 - 07:44 PM
Agree with Pilesar. Please explain your choice. Cost cannot be the driver.
#4 Ali4269278331
Ali4269278331
  • 31 posts
Posted 18 April 2024 - 12:04 PM
we have valve specification document that prepared by project designer and he select a ball valves for low pressure steam service.
#5 shvet1
shvet1
  • 476 posts
Posted 18 April 2024 - 11:17 PM
What does PTF2 / VIT / NIT stand for?
Edited by shvet1, 18 April 2024 - 11:30 PM.
#6 breizh
  • 6,941 posts
Posted 19 April 2024 - 05:12 AM
Hi shvet1,
PTFE,Viton,Nitrile.
Ali,
Why ball valve ?  for isolation or for throttling or.....
https://qrcvalves.co...t-applications/
#7 shvet1
shvet1
  • 476 posts
Posted 19 April 2024 - 05:24 AM
@breizh
PTFE - seems no as there is PTFE and PTF2 in the table
@Ali
Are you asking about the item 511 AG 2C7?
#8 Ali4269278331
Ali4269278331
  • 31 posts
Posted 20 April 2024 - 12:31 PM
Hi shvet1,
PTFE,Viton,Nitrile.
Ali,
The project designer consider for isolating the steam service. but if want to isloate the line, the ball valve had leakage too much. finally, i decide to change with gate valve if possible.
#9 Ali4269278331
Ali4269278331
  • 31 posts
Posted 20 April 2024 - 12:36 PM
@breizh
@Ali
the 511 AG 2C7 item code isnot suitable, Now i consultant with valve shop, he said i can change the PTFE that work in 300oC but i think fail the seal ring after 3month in service.
#10 breizh
  • 6,941 posts
Posted 20 April 2024 - 07:07 PM
HI,
PTF2 material :
https://store.csides...0-256--PTF2-000
Yes, Gate valve is a better option.
#11 shvet1
shvet1
  • 476 posts
Posted 22 April 2024 - 12:30 AM
HI,
PTF2 material :
Seems PTF2 is specific manucatrurer's article, not a material. While in the table above PTF2 is mentioned as a material.
Then which one item is suitable? ))) Why did you share this doc?
As per my experience with PTFE the real temp limit for intermittent service of 95% PTFE availble on market is 180-220°C.
The rest 5% 240-260°C but the price is high and you shall rely on manufacturer/supplier reputation/references instead of specification.
#12 Ali4269278331
Ali4269278331
  • 31 posts
Posted 24 April 2024 - 12:53 PM
HI,
PTF2 material :
Thanks, perfect. i should be use of this way.
