Pump Dischrge Control Valve Sizing
pumps discharge control valve pressure drop
#1 Lyne
Lyne
  • 60 posts
Posted 04 June 2024 - 08:25 AM
How to set the pressure drop for the control valve at a pump discharge? I have different regimes and the control valve is at the booster pump outlet. is there a special requirements for such control vales ?
Thank you
#2 snickster
snickster
  • 84 posts
Posted 04 June 2024 - 02:25 PM
Here is typical sizing criteria for good controlability:
Minimum Cv Capacity (Cv Required)
The selected control valve trim capacity (Cv selected) shall meet the
following:
1) An equal percentage trim shall operate below 93% travel at
maximum flow condition. If no maximum flow condition is
specified on the ISS, then the trim shall operate below 85% travel
at normal flow condition.
2) A linear trim and quick opening trim shall operate below 90%
travel at maximum flow condition. If no maximum flow condition
is specified on the ISS, then the trim shall operate below 75%
travel at normal flow condition. Anti-surge control valves shall
operate below 55% travel at maximum flow condition.
3) A modified parabolic trim shall operate below 90% travel at
specified on the ISS, then the trim shall operate below 80% travel
Commentary Note:
The specified percentage (%) travel positions are for sliding stem type
valves and need to be converted to degrees opening for rotary type
control valves.
Edited by snickster, 04 June 2024 - 02:29 PM.
#3 breizh
  • 7,009 posts
Posted 05 June 2024 - 12:34 AM
To add to Snickster's reply, a paper and an excel sheet I prepared years ago.
#4 walidd_23
walidd_23
  • 27 posts
Posted 10 June 2024 - 03:38 AM
Hello
First of  all you need to determine the worst case which corresponding the maximum calculated Cv considering the following:
  1. Min pressure drop of control valve 0.5 -0.7 bar
  2. Max Operating pressure at receiving vessel or destination (HPA)
  3. Max liquid level at receiving vessel
  4. Rated Flowrate
  5. Min liquid level at supply vessel
With this condition you will determine the max flow valve condition and rated head of the pumps.
After that you  can do the calculation for normal flow with normal operating pressure and level, and min flowrate to determine the full operating of the control valve.
For better estimation it is good to have pump curves  for normal and min case , I have attached and example for the valve hydraulic calculation of this 3 cases using Flowmax
Attached File  Valve Sizing Cases .pdf   397.38KB   99 downloads
Edited by walidd_23, 10 June 2024 - 04:53 AM.
#5 billjones66
billjones66
Posted 10 November 2024 - 06:16 PM
Here are some free control valve sizing worksheets in excel available for download: https://www.industry...alve_sizing.php
