Gasoline Storage Tank
14 replies to this topic
#1 Lucianaa
Lucianaa
  • 13 posts
Posted 29 August 2024 - 03:23 PM
Dear all,
I am evaluating the losses of gasoline stored at the terminal. Some variables such as tank measurements, valves, membranes, tank bottom leaks, monitoring of tanks during operations, but nothing justified the losses. Any guidance, suggestions for evaluation?
The tanks are atmospheric and have membranes.
Thank you for your assistance.
  • 7,058 posts
Posted 29 August 2024 - 06:25 PM
Hi Luciana,
Consider this resource
#3 Lucianaa
Lucianaa
  • 13 posts
Posted 29 August 2024 - 09:42 PM
Hi Luciana,
 Thank you, Breizh.
#4 shvet1
shvet1
  • 476 posts
Posted 02 September 2024 - 12:25 AM
What do you mean losses - environmental issues or process losses?
#5 Lucianaa
Lucianaa
  • 13 posts
Posted 03 September 2024 - 09:07 AM
Hi Shvet1,
I refer to process losses
#6 fallah
  • 5,026 posts
Posted 03 September 2024 - 09:16 AM
Hi Shvet1,
Do you mean loss of inventory?
#7 Lucianaa
Lucianaa
  • 13 posts
Posted 03 September 2024 - 11:26 AM
Hi Shvet1,
Hi fallah,
Correct!
#8 fallah
  • 5,026 posts
Posted 03 September 2024 - 12:01 PM
Hi fallah,
Correct!
In general, and roughly by subtracting the unloading volume from loading volume...
#9 Lucianaa
Lucianaa
  • 13 posts
Posted 03 September 2024 - 10:03 PM
Hi fallah,
Correct!
Hi
Thank you Shvet1! But the question is not how to calculate, but how to investigate/identify losses in the process, which are above the acceptable level.
#10 shvet1
shvet1
  • 476 posts
Posted 03 September 2024 - 11:34 PM
Study precious mass metering of incoming/outcoming flows and storage inventory. Spread practices are mass flowmeters and trucks/containers weighting.
Note that such measurements usually refer to fiscal metering and mutual settlements. Not a simple task, I should warn you, as modelling methods usually greatly underestimate losses.
As per my experience with such issues every Operator establishes its own losses rates based on local record/practice.
Edited by shvet1, 03 September 2024 - 11:38 PM.
#11 breizh
  • 7,058 posts
Posted 04 September 2024 - 12:58 AM
Hi Luciana,
Important to validate the losses over a significant period of time. 1 year is a good period of time. it will take into account the seasons and the temperature change, if you consider losses to the vent.
Of course, accurate measurements are required, with calibration records for mass flow meters and truck scales.
Make sure no one is taking advantage for its own benefit. Be careful, I've witnessed such behavior!
People are smart.... I've seen truck driver replacing latex emulsion with water, same density.
Good Luck
#12 Lucianaa
Lucianaa
  • 13 posts
Posted 04 September 2024 - 07:14 AM
Hi Luciana,
Good Luck
Exactly!
We work with arrow volume and sometimes the flowmeter does not count the same volume. How do you make sure the arrow is correctly calibrated? Complicated!
#13 breizh
  • 7,058 posts
Posted 04 September 2024 - 07:36 AM
Hi Luciana,
You should have a master flowmeter calibrated by 3 rd. party with all the certificates to justify its accuracy. You can install it in series with your existing flowmeter to check the difference between the meters, if any. You need to install a spool piece for this master meter to be installed time to time for Check.
#14 shvet1
shvet1
  • 476 posts
Posted 04 September 2024 - 08:25 AM
"arrow volume" - what does it mean?
"flowmeter does not count the same volume" - the same as what?
"How do you make sure the arrow is correctly calibrated?" - why not to pump through it a controlled amount of a product?
Do you understand that there exist no a mass flowmeter that measures the mass flowrate? All industry sensors provide indirect measurement with recalculations based on assumptions of liquid properties.
What actual type of flowmeter do you use for this metering?
Edited by shvet1, 04 September 2024 - 09:08 AM.
#15 breizh
  • 7,058 posts
Posted 04 September 2024 - 10:34 PM
Hi Luciana,
Can you share with us the reference and/or a picture of your meter? It should deliver M3 (accumulative meter), right? It looks like a water meter in my country!
