Any feedback and guidance is much appreciated.
Posted 09 September 2024 - 11:49 AM
Posted 09 September 2024 - 01:35 PM
You don't say whether this is a shell/tube exchanger. Is a tube rupture a reasonable scenario? Or some way for the process side to enter the water side? There is also a possible scenario of pool fire at the exchanger. By asking your questions, I get the impression you are new to relief scenarios. Consider all additional cases! Search on the world wide web for a pressure relief scenario checklist and consider each case to see whether it requires overpressure protection. Document the analysis so it can be audited in the future. Even if you determine 'this case does not apply' then document those scenarios also.
Posted 09 September 2024 - 01:53 PM
A P&ID would help!
Psv Downstream Line SizingStarted by Guest_Abdessamed1961_* , 03 Mar 2026 |
Lng ExchangerStarted by Guest_guoyinyanliner_* , 10 Feb 2026 |
Best Heat Exchanger Type For Gas HeatingStarted by Guest_Gole_* , 29 Jan 2024 |
