Separation Technology For Separate / Distillate Hcl From Water Mixture
separation distillation extraction absorption
#1 dpunnn
dpunnn
  • 11 posts
Posted 11 September 2024 - 08:15 PM
I want to Separate HCL from water mixture, the components as follows.
Feed : 5,000 kg/jam
HCL 3.6%
Water 96.2%
H3PO4 0.2 %
Product that I desired.
HCL 4.8% ~ 5.0%
Water 95%
What separation technology thatt fits to this issues,
First, I Think uses distillation tower, but I concern that the HCL and water are azeotropic matters.
Note: this plant / process purpose is recovery HCL, existing was used Double Effect Falling Film evaporator (to separate the Phosphoric Acid) and I want to continue for puring the HCL to be 5%.
What do you expert thinks?
#2 shvet1
shvet1
  • 476 posts
Posted 12 September 2024 - 12:26 AM
membranes
#3 breizh
  • 6,939 posts
Posted 12 September 2024 - 03:09 AM
Consider this resource to support your work:
https://www.dedietri...ration-hcl-acid
Note: With your input, azeotrope is not a concern .
