Steam Mix
#1 kaidlut
kaidlut
  • 33 posts
Posted 13 September 2024 - 07:03 AM
Someone calculate this for me ,thanks.
if we have a Saturated steam (3.57Mpa-G,246.06℃)mix with Superheated steam (4.15Mpa-G,411.07℃)to produce 100.31Ton/h,3.56Mpa-G,328.85℃ steam,then,What is the saturated steam flow rate and superheated steam flow rate respectively?
Edited by kaidlut, 13 September 2024 - 07:35 AM.
#2 shvet1
shvet1
  • 476 posts
Posted 13 September 2024 - 07:09 AM
Why are you evading conducting this yourself?
Edited by shvet1, 13 September 2024 - 07:10 AM.
#3 kaidlut
kaidlut
  • 33 posts
Posted 13 September 2024 - 07:30 AM
Actually, to verify my own calculation results
#4 breizh
  • 7,066 posts
Posted 13 September 2024 - 07:36 AM
Kaidlut ,
If you want support, share with us your work.
Someone surely will comment.
Right now, perform a mass balance and enthalpy balance.
For enthalpy data plenty of calculators on line. I've attached my favorite for this type of calculation.
Quite simple.
quantity overheated :56.635 t/h
quantity saturated : 43.674 t/h
#5 shvet1
shvet1
  • 476 posts
Posted 13 September 2024 - 07:43 AM
Why not to verify results by making the same using different methods and/or means? Why do you need other person behind you?
Why don't you trust Hysys? Why do you trust "that guy from the internet" more than Hysys? Have you considered that the software, which has been evolving for 20 years, could make mistakes in basic operations? Are you sure that we are skilled engineers and not amateurs? Are you certain that we are not a Tencent/OpenAI experiment in human neuro-mimicking?
You do not trust Hysys. Ok. Why not to do the same by Aspen+ or a free modelling software?
https://en.wikipedia...cess_simulators
Edited by shvet1, 13 September 2024 - 08:42 AM.
#6 kaidlut
kaidlut
  • 33 posts
Posted 13 September 2024 - 08:50 AM
really appreciate for your share
Kaidlut ,
Quite simple.
