i simulated a column for separating diethyl ether from methanol and it always output this error i'm not sure how to fix.
Posted 13 November 2024 - 08:39 PM
Posted 13 November 2024 - 08:55 PM
Radfrac unit will not give the exact same answer as DSTWU. In addition to the inputs, add specifications and variables to allow the Radfrac unit to find its own answer. Simple Specs would be Reflux Ratio and the flow rate of one of the product streams. Simple Vary would be the condenser and reboiler duties.
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
Teg Dehydration Stripping ColumnStarted by Guest_SidRah_* , 08 Sep 2025 |
