Ditance Between Globe Valve And Ball Valve
valves
10 replies to this topic
#1 sima-f
sima-f
  • 25 posts
Posted 05 January 2025 - 01:44 AM
Hi
generally, in drain line, A globe valve located at 600 mm minimum from the block valve to avoid the freezing of the globe due to the low metal temperature,
i want to know why 600 mm?  Please clarify about the reference of 600 mm and why this  distance is mentioned generally as the minimum.
#2 Dacs
Dacs
  • 457 posts
Posted 05 January 2025 - 02:00 AM
Engineering practice. The value differs between companies.
If that valve is quite critical, you can perform an energy balance to determine the minimum expected temperature of that valve.
#3 sima-f
sima-f
  • 25 posts
Posted 05 January 2025 - 02:18 AM
thanks DAC
Please explain a little more about how to calculate the real distance with Hysys?
#4 breizh
  • 6,940 posts
Posted 05 January 2025 - 07:28 AM
Consider this link to support.
https://www.cheresou...and-ball-valve/
in case:
https://qrcvalves.co...s-globe-valves/
#5 sima-f
sima-f
  • 25 posts
Posted 05 January 2025 - 07:46 AM
Hi Breizh
Thank you, but still did not receive a suitable answer regarding how to calculate this distance.
#6 latexman
  • 1,894 posts
Posted 05 January 2025 - 08:07 AM
I believe the resulting temperature from the isenthalpic expansion process of the first valve is what Dacs meant.  No one but you mentioned calculating the real distance.  I'm not sure if that is meaningful.  Can you explain?  If the minimum expected temperature is within the globe valves specs, then it's okay.  If not, put a heat exchanger in between?
#7 breizh
  • 6,940 posts
Posted 05 January 2025 - 11:02 PM
Share with us information about your product and operation condition.
What is your issue with the minimum distance between valves?
It's always case by case answer.
More info better answer.
#8 sima-f
sima-f
  • 25 posts
Posted 06 January 2025 - 03:11 AM
I just wanted to understand the reason for considering at least 600mm as practice.
This concept considered in manifolds for drain connections.
#9 Dacs
Dacs
  • 457 posts
Posted 06 January 2025 - 05:08 AM
And we already answered. My answer below:
#10 latexman
  • 1,894 posts
Posted 06 January 2025 - 05:53 AM
I recommend you inquire in your company's group that supports this engineering practice.
#11 breizh
  • 6,940 posts
Posted 10 January 2025 - 07:07 AM
From Shell DEP 31-38 01 25,
Attached the reference, based on experience.
Good luck,
