Butadine Storage And Handling
butadiene
#1 engmmostafaa22
engmmostafaa22
Posted 08 February 2025 - 06:59 AM
I have a project for construction Spherical Tank for Storage Butadiene with capacity 3700 ton and i'm not familier with the selection Pumps, BOG compressors, Propan air cooler, Presure vessels for Heat exchangers is any one have PID for this process. if the Butadiene will storage at 0.42 bar at tempreture -4C could and the requested flow rate for discahrge is 500 M3/hr can you help me for select all equpimpmnet
#2 latexman
  • 1,894 posts
Posted 08 February 2025 - 11:37 AM
I cannot Engineer that; I am retired. But, surely, you are doing your due diligence, or looking to subcontract it out to an experienced Engineer or firm. These may help:
https://www.american...ance-Manual.pdf
https://www.airgas.com/msds/001008.pdf
#3 breizh
  • 6,942 posts
Posted 08 February 2025 - 06:12 PM
To add to Latexman's reply, a document about butadiene.
https://www.cheresou...adiene-storage/
You definitely need to contract a company familiar with this product to design and manage the project.
https://rajyn7.wixsi...age-tank-design
Notes: Your supplier should be able to support or provide advice.
I believe you will need more than 1 sphere for your project, don't forget maintenance.
Same for ancillaries (pumps, chillers,)
You did not mention how you will receive your material. My time in Indonesia for SB latex production, we built a Jetty to receive the Butadiene.
Good luck anyway.
