Pulsation Device In Reciprocating Compressor
Posted 17 February 2025 - 02:52 AM
Posted 17 February 2025 - 08:06 AM
Hi, As per API 618, we need a pulsation dampener irrespective of the motor rating. Based on the final discharge pressure and kW/cylinder rating, API 618 classifies which type of approach study is to be performed. Default is approach 1 which is pulsation dampener sizing. Minimum size of pulsation dampener on suction and discharge side shall be at least 0.03 m3 or else as per the formula stated in 618 whichever is greater. Theoretically, If the suction and discharge pipe sizes are very much higher, then the pipes can be considered as dampeners with orifices before and after the compressor cylinders to reduce the pulsation limits within API 618. However, this practice is not followed for API compliant machines.
Posted 18 February 2025 - 02:47 AM
Hi Krishnasagar,
Posted 19 February 2025 - 07:46 AM
Hello The amount that the pipe size must increase to absorb the pulsations is beyond my knowledge. Vendors typically take into account the pipeline's orifices to limit pulsation in the initial phase only. However, following the pulsation study, these orifice requirements will be verified. Higher rod loads will result from the installation of orifices since they will increase power consumption and differential pressure across the machine. Therefore, we typically ask vendors to ensure that all of these are already taken into account in their design at initial phase. Pulsation dampeners are mandated by API 618, as Approach 1 is default, which says the minimum size of the dampener as 0.03 m³. With respect to the study, the vendor will lower the pulsations by installing an orifice on the lines, considering internals inside the dampener, etc.
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Centrifugal Compressor TroubleshootingStarted by Guest_sggifrance@gmail.com_* , 14 Sep 2025 |
