Valve Cavity - Pressure Relief Valve
#1 CS10
CS10
  • 32 posts
Posted 20 February 2025 - 01:58 AM
Hi everyone,
I am working on checking the Pressure Relief Device Calculation and Generating Datasheet for the PSV in the attached file PSV-212 and PSV-312?
Take an example for PSV-212, where the existing model is Swagelok (D and Orange).
Is there calculation procedure or guideline for me to do the calculation to check the required and rated capacity of the PSVs?
As per API 6D Guideline, these two PSV will serve as Valve Cavity pressure relief. However, I more than happy if you could please give me some more insight into the calculation required.
Many thanks,
Edited by CS10, 20 February 2025 - 01:59 AM.
#2 snickster
snickster
  • 83 posts
Posted 21 February 2025 - 11:59 PM
Attached is an old API RP 521 section that provides equation and guidance for thermal relief valve sizing.  To be conservative you could take the maximum solar radiation for the area your valve is located can be used to calculate "H" in the calculation.
#3 breizh
  • 6,939 posts
Posted 22 February 2025 - 02:29 AM
Consider this resource, similar to above. 7-4-8-2
#4 CS10
CS10
  • 32 posts
Posted 25 February 2025 - 02:37 AM
Thanks snickster and breizh for sharing the the Standard and reference.
