Discussion - Predict Storage Tank Heat Transfer Precisely By Jimmy D K
#1 raj shekhar
raj shekhar
  • 42 posts
Posted 25 March 2025 - 06:13 AM
I am try to use the calculation method defined in the paper published by Jimmy D Kumana and Samir P Kothari to Predict Storage tank heat transfer precisely.
Here is the link of a post in this forum -
https://www.cheresou...othari-article/
https://www.cheresou...-storage-tanks/
is it possible to use this calculation method with a vertical, outside, atmospheric storage tank with an agitator, which adds forced convection component in the calculation.
Will it be correct to replace the Natural convection parts in the calculation with a forced convection?
here are some articles showing how to calculate the inside heat transfer coefficient of tank with an agitator.
https://pdhonline.co...k102content.pdf
https://www.thermope...om/content/547/
please share your thoughts. it will be really helpful.
Thank you,
Raj Shekhar Ghosh
  • 1,639 posts
Posted 25 March 2025 - 03:35 PM
There are many variables in calculating storage tank heat transfer. In my opinion, precise and accurate calculations would require tuning the parameters against a real-world dataset. An easier task would be to calculate a conservative heat transfer to consider the worst case in whichever direction was important. I have calculated storage tank heat transfer when designing compressors or refrigeration systems for cryogenic boiloff and for specifying molten polymer tank heat tracing, but I never relied completely on the accuracy of my calcs and always included a generous safety factor.
#3 breizh
  • 6,942 posts
Posted 25 March 2025 - 07:48 PM
Should be possible, considering heat transfer correlation for forced convection instead of natural convection (in the liquid part) together with heat generated with the agitator during rotation. If possible, start a model and compare with data on site. This will tell how much margin is needed.
https://www.uomus.ed...024_4231334.pdf
#4 Dacs
Dacs
  • 457 posts
Posted 25 March 2025 - 11:35 PM
In addition, you may also need to account for external heat effects, such as heat exchange to/from ambient and solar insolation effects.
#5 raj shekhar
raj shekhar
  • 42 posts
Posted 28 March 2025 - 03:44 AM
Thank you Dacs, breizh, and Pilesar for sharing insights.
